£8 50GB for existing customers?
RosieBla_936107
The money saving expert website is advertising a deal that is meant to expire Sunday 30th of April, offering 50GB for £8 for new customers. When I checked on the Smarty website, I can only see a plan for 60GB for £10. Will Smarty offer the 50GB for £8 for existing customers as well?
Hi @RosieBla_936107 . Usually, the answer is 'yes' but you will need to web chat with Support to get that.
Also remember that, if the sim is part of a group, you will not also get the 10% discount on the plan.
12 REPLIES 12
Great, thanks. I've only just seen the web chat, will give it a go!
Jamie
I have got the discount - £7.20 for 50GB
@Jamie  That's quite odd! The T&C's specifically state that you won't get any other discounts while on this offer. https://cdn.smarty.co.uk/files/smarty-promo-15Mth50GB8Mar24Direct.pdf point 9
sam611
Click on moneysavingexpert link and it takes you direct
Steven-
Can I have the £8 for 50GB
@Steven-  You can choose any plan that is on offer when you wish to purchase.
Steven-
Can I change my plan to the £8 for 50GB please regards Steven Evans.
@Steven-  You choose your plan from your own account dashboard.
ScottD
I’d like this deal to please 🙏
@ScottD If a plan is available, you can either choose it from your dashboard or request a special offer from Smarty Support via web chat.
ScottD
Hey thanks for your reply not available on my dashboard and after speaking to the agents they said no 😔
