04-28-2023 12:02 PM
The money saving expert website is advertising a deal that is meant to expire Sunday 30th of April, offering 50GB for £8 for new customers. When I checked on the Smarty website, I can only see a plan for 60GB for £10. Will Smarty offer the 50GB for £8 for existing customers as well?
04-28-2023 04:51 PM
Hi @RosieBla_936107 . Usually, the answer is 'yes' but you will need to web chat with Support to get that.
Also remember that, if the sim is part of a group, you will not also get the 10% discount on the plan.
04-28-2023 04:51 PM
04-30-2023 06:34 PM
Great, thanks. I've only just seen the web chat, will give it a go!
04-14-2024 01:06 PM
I have got the discount - £7.20 for 50GB
04-14-2024 02:15 PM
@Jamie That's quite odd! The T&C's specifically state that you won't get any other discounts while on this offer. https://cdn.smarty.co.uk/files/smarty-promo-15Mth50GB8Mar24Direct.pdf point 9
04-30-2023 07:13 PM
Click on moneysavingexpert link and it takes you direct
11-29-2023 07:53 PM
Can I have the £8 for 50GB
12-01-2023 10:13 AM
@Steven- You can choose any plan that is on offer when you wish to purchase.
12-01-2023 10:16 AM
Can I change my plan to the £8 for 50GB please regards Steven Evans.
12-01-2023 06:25 PM
@Steven- You choose your plan from your own account dashboard.
02-29-2024 06:22 AM
I’d like this deal to please 🙏
02-29-2024 05:01 PM
@ScottD If a plan is available, you can either choose it from your dashboard or request a special offer from Smarty Support via web chat.
02-29-2024 07:07 PM
Hey thanks for your reply not available on my dashboard and after speaking to the agents they said no 😔
