14-01-2025 07:09 AM
I have recently joined SMARTY. Soon after activating, I got (what I suspect is a generic) message advising me to update my APN if I was interested in roaming. I am, so I did.
However, due to finger trouble, I entered "mob.asn.net" (note the N in ASN) and not "mob.asm.net". Surprisingly (to me) this worked. Intrigued, I started experimenting and all the variants that I tried (including a null entry) worked.
Why/how is this?
Regards, M.
14-01-2025 09:10 AM
@mprowe If you are not actually roaming, then I do not think that it affected anything.
My limited understanding is that it comes into play when you are registering with a foreign network.
14-01-2025 15:29 PM
APN only matters when outside the UK. You can put Mickey Mouse in the APN field and data will work just fine.
15-01-2025 09:52 AM
What is the position in reverse?
If I have a French SIM (Free) in my router, will Three complain because the APN info is wrong?
