08-31-2023 04:57 PM
Help, I am unable to make a voice call in the USA, but I can an SMS. I have purchased an out of plan add on and set my roaming on my Android phone. The APN appears correct also. But the call is ended immediately. What have I not done?
08-31-2023 05:17 PM
Found it. For all USA travellers, switch off automatic network selection for your Smarty SIM and make sure AT&T is not selected. As they do not appear to work. I selected T-Mobile and it worked perfectly.
08-31-2023 05:17 PM
08-31-2023 05:51 PM - edited 08-31-2023 05:54 PM
Will also work on Verizon, at least it did for me in Phoenix earlier this year.
Depending on the length of your stay, you may wish to look at the plans from these MVNO’s , who all offer eSIM if you have an eSIM compatible phone :
Mint Mobile, an MVNO on T-Mobile. Can only buy plans for periods of 3, 6, or 12 months, not monthly. (Formerly owned by Ryan Reynolds, AKA “Deadpool” but recently sold to T~Mobile)
Tello - MVNO on T-Mobile. Offers monthly plans.
US Mobile - Their eSIM defaults to Verizon, but their physical SIM card kit comes with two SIM cards - Black, which connects to Verizon, and White, which connects to T-Mobile. You choose the SIM card that offers you the best coverage. Offers monthly plans.
