06-02-2025 15:50 PM
I have made the appropriate settings changes as described in the help article but still don't get phone use in Norway. It's a Pixel 8 pro. Any suggestions?
07-02-2025 09:50 AM
@GerardE_1797268 Try Manual Network search and try each network until you find the best one.
07-02-2025 10:58 AM
There are only two services N Telenor and Telia N..... neither of which works.
07-02-2025 10:33 AM - edited 07-02-2025 10:35 AM
@GerardE_1797268 Just to be clear (as I don't know what you will consider to be the 'appropriate' settings changes or which specific help article you're referring to), have you set your APN setting to 'mob.asm.net', and do you have data roaming turned on on the phone?
What exactly is happening? Are you seeing 'no service', or do you have a signal but data is not working on it?
07-02-2025 10:51 AM
Yes, I have done that
07-02-2025 10:54 AM
I am connected to a signal but get an error message that I have not been connected to the service (N Tel)
07-02-2025 11:58 AM
@GerardE_1797268 Does that apply to calls, texts and data?
Is there definitely a reasonable signal where you are? - you did not mention how many bars are showing
07-02-2025 12:19 PM
Yes, I have full signal in Oslo airport
07-02-2025 12:21 PM
I can receive calls perfectly
07-02-2025 12:27 PM
@GerardE_1797268 Sorry, but I am now confused. What part of the service are you not able to access then?
07-02-2025 14:02 PM
I can receive calls (from UK numbers only) but can't make any calls at all.
