Unable to make calls and receive calls
Simone_2064666
Hi all,
It has been a while since I cannot make calls and receive calls.
Send/receive text and data work fine.
I tried on another phone, but nothing.
What can it be?
Thanks for your help
6 REPLIES 6
SmartyTrousers
@Simone_2064666 It may be that your phone isn't compatible with Smarty's 4G calling, see this page for more details (note that I don't think the list of incompatible devices on that page is exhaustive).
Thanks for your reply.
I am not a caller, but I can say that I have been not able to make calls since last month. Additionally, last weekend I received a call regularly
Hi  Simone_2064666,
I unfortunatly cannot access your plan on this platform and I will need to look into your account to get a definite answer. Our customer care team are on hand to help  https://smarty.co.uk/contact available daily from 8am – 8pm.
Also, my phone is a Redmi Note 9 which is not listed and supports VoLTE/4G calls
@Simone_2064666 As I said, I don't think the list is exhaustive. Also, your phone supporting VoLTE doesn't necessarily mean it's compatible with Smarty's specific VoLTE configuration, unfortunately.
Ok thank you.
