Transferred number not receiving calls
โ09-12-2022 21:15 PM
I had a SMS at 1800 to say number transfer successful took a while for my old SIM to go offline. I can now call from my Smarty SIM on the new number. But I can't receive anything there call just terminates.
โ10-12-2022 12:04 PM
โ12-02-2025 09:19 AM
Hi Pyemania - I'm having the same issue for a Sim I bought for my Mum. Was it resolved? Waiting to hear from Smarty.... Best wishes, Steve
โ12-02-2025 09:42 AM
@SteveBe_3173270 The original post was in Dec. 2022. If your number shows correctly in your Account Dashboard, but your phone sends a different identity when it calls out, try a Network Reset within the Settings.
โ12-02-2025 09:54 AM
HI Smarty Guru - thanks I've just been helped by Srikanth who has also mentioned the same thing about Network settings reset. It seems to have worked. Many thanks!!
โ12-02-2025 10:08 AM
@SteveBe_3173270 That's good news!! This is a common issue because the phone 'remembers' the first number allocated to the sim and needs to be 'retrained'.
