Routers, sims and calls
โ21-06-2023 10:43 AM
Hello, I've put a sim in a router should I be getting calls and texts on my mobile phone? Thanks.
โ21-06-2023 11:07 AM
Hello @PeterTu_2121270 The sim will only deliver a signal to the device it is in.
Sounds like your router is getting the signal - your phone will not also get that signal.
If you are able to make wifi calls on your phone then it is possible that it would connect via the router, but not otherwise.
Also, have you got correct settings on the router so that you can receive data at all?
โ22-06-2023 10:15 AM
Thanks for the help.
