Roaming - Samsung
SteveGa_1733910
Hello, I tried following the Smarty advice to set my Samsung phone Roaming up - having received an email from Smarty with instructions. Upon checking, the phone's setting already had the correct Access Point Name. Is it therefore as simple as selecting "Data Roaming" (on a slide switch under settings) and all will be well when abroad please? Thank you.
@SteveGa_1733910 Yes, that should be the case. Only the APN needs to be checked so that it reads mob.asm.net and then mobile data roaming allowed.
1 REPLY 1
