renew my plan
ianmac2225
I want to renew my plan each month using my credit card. How do I do this?
Look at the bottom right of your app :
Select “You”
Then select “Account Settings”
Then select “Payment Settings”
Its quick and easy to do
Select “You”
@ianmac2225  As @JJP2 says and do ensure that 'auto-renew' is enabled then you do not need to bother yourself further with it.
