โ16-12-2022 13:59 PM
Hi, anyone noticed a reduced phone signal in the LS27 8 area? Over the last 10 days I have noticed a drop in mobile phone signal indoors compared to what it was before.
โ17-12-2022 16:28 PM
Thank you, I've had a look at the status checker and just wondered if the work being done is the reason for the drop in signal.
โ17-12-2022 14:33 PM
I would have a look at our network status checker https://smarty.co.uk/network-status-checker/ it is possible that there is some work in your area. If so, this will provide you with updates ๐
โ31-01-2023 11:04 AM
yes if there is work going on in your area that will be affecting the quality of the signal
โ30-01-2023 22:24 PM
no signal here parts of kent
