Quality of signal- poor !
Radosla_2063533
Almost all the time there are difficulties and image distortions while watching a movie or listening to music. The quality and speed of data flow is not satisfactory. If that doesn't change, I'll change the operator.
@Radosla_2063533  Unfortunately, this does sometimes happen, so changing networks may be the only option, but check carefully first and 3 network is likely to be similar as Smarty runs on it.
I have replied on the other thread you started about this.
