Phone won't accept calls or dial out
JosHoyte_507983
My phone will not accept  or dail  out
1 REPLY 1
@JosHoyte_507983  Have you checked your account dashboard?
You should be able to see your own number and also details of your current Smarty plan.
If that looks fine, next go to the Network Status checker to see if there is any local mast problem.
If there is no apparent problem, look at this article: https://help.smarty.co.uk/en/articles/952851-problems-with-your-connection?_gl=1*1ne1mnr*_ga*OTk5Njk...
