Phone settings
Options
โ08-07-2023 12:07 PM
I think I've changed my settings to use abroad but I'm not sure? I do I know if if it's done correctly and if it will work when I'm away? I'm going to Greece. Many thanks ๐
1 REPLY 1
Options
โ09-07-2023 10:41 AM
Hi @ColinBro_122924 the main thing is you need to make sure the APN is mob.asm.net - if this setting is correct then it'll work abroad
