05-21-2023 10:13 PM
05-22-2023 09:19 AM
Hello @Carolbe_1996617 . That will be linked to your router and would have been sent to you when you got it. I don't think we can tell you what it is. (Sometimes, it is printed on a label on the router - it stops people logging in from outside your property but you can find the password easily).
05-22-2023 09:51 AM
@Carolbe_1996617 If you know the brand of router, you may get some help on this website: https://www.routerpasswords.com
07-18-2023 10:55 AM
IT'S A 4G USB DONGIE WIFI
07-18-2023 01:45 PM
@SatnamS_1392082 So in that case, you should try my earlier suggestion once you know the brand.
