Pac code isn't working
โ06-10-2024 15:26 PM
So i've activated my Smarty sim, and want to keep my old number.
Problem is it won't process, i've tried two different pac codes now and input my old phone number, and it just comes back with this; Please re-check if your number is correct and try again
Can anyone help, otherwise i'll have to cancel my contract and stay with Giffgaff which i don't want to do.
โ06-10-2024 16:46 PM
Hey MichaelPh_88902,
If you contact the customer care team they can assist and investigate https://smarty.co.uk/contact available daily from 8am โ 8pm.
โ30-01-2025 13:34 PM
Hi I took have this issue it just keeps saying
Please re-check if your number is correct and try again. But I've copied and pasted from the text they sent me
โ30-01-2025 13:41 PM
@LindseyB_334162 In that case, you should firstly simply type in the code rather than copy and paste.
If that doesn't work, is the PC code less than 30 days old? They expire if unused.
Still no success? Then follow advice from @Rebekah_150 in the post above yours.
