โ27-04-2023 15:27 PM
Had all sorts of hassle getting my PAC code to be accepted, the chat was hopeless, he kept saying enter the number with 07xxx xxxxxx but the page insists the "0" is removed.
Anyway, PAC codes have Upper Case letters, like most people i just entered lower case and it refuses it because the code is set to accept Upper Case only.
Can I suggest that Smarty either change the code to accept lower case inputs or insert a reminder to use Upper Case letters
โ27-04-2023 16:34 PM
Thanks for pointing that out @MartinM_1960762 - really useful info.
BUT...if they gave you the code with upper case letters, was there a reason why you did not try it exactly that way when lower case didn't work?
โ27-04-2023 16:18 PM
Thank you for your sharing @MartinM_1960762 , I'll pass it on to our tech.
