15-09-2024 02:29 AM
I have a week left before my plan renews and I ran out of data. Want to buy 'out of plan' to tide me over.
If I get the £5 add on, how much data does that include? Trying to estimate if it would last me enough time.
Thanks.
15-09-2024 10:03 AM
@kyaelle You need to check out the Price Guide : https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*1a3d8zl*_ga*MjA5ODc3MzU1My4xNzI2MTM1Njc3....
Page 14 - you buy add on data by amount of Gb.
The add on you are looking at is for making international calls, calls to non-standard numbers, use while roaming non EU etc.
15-09-2024 10:29 AM
Can you not see the add ons in your Smarty app? The £5 data add on gets you an additional 5GB of data.
15-09-2024 10:03 AM
