10-05-2024 17:30 PM
Silly question... I've purchased an out of plan add on for data and calls for use out side the EU. Do I need to turn data roaming on while out side the EU or leave it turned off to access the add on plan?
11-05-2024 14:26 PM
Many Thanks. That makes sense. Also thanks for the heads up on a local sim.
11-05-2024 18:00 PM
@Charles_1317619 De nada señor.
11-05-2024 09:12 AM
@Charles_1317619 You will need it turned ON as you WILL be roaming - albeit that you need to pay for it.
If you are somewhere that Price Guide tells you will cost a lot for service, may be worth considering an eSim if your phone can accept it. This is a virtual sim through a provider and will allow you to use data while roaming - calls can be via WhatApp or similar. (Some sims will also sell you voice minutes and texts)
11-05-2024 14:26 PM
11-05-2024 18:00 PM
10-05-2024 21:05 PM - edited 10-05-2024 21:07 PM
Turn data roaming ON. whenever you are outside the UK, whether that’s in the EU or outside the EU.
If you don’t, your phone won’t connect outside the UK
