10-15-2023 05:29 PM
Currently in Spain on holiday. Should everything work as it does in UK ? Has I'm not able to call mobiles . Landlines work fine and data is working fine. Just not able to call mobiles??
10-15-2023 05:34 PM
What happens when you try to dial a mobile number ?
Have you stored the numbers of your contacts in international format ? I.E. +44 7xxx xxx xxx ?
As a short term solution, you can call people through WhatsApp, providing our course they also have WhatsApp. As your data is working, over which WhatsApp works, then this would be a workable short term fix.
Also, when abroad, it’s a good idea to manually select a network, as sometimes, the network your phone automatically connects to may not have roaming agreements with Smarty. Although, as you can call landlines, this probably doesn’t apply to you right now.
10-15-2023 05:38 PM
I will try the things you have told me about 👍
10-15-2023 06:11 PM
Hope they work - let us know if they do, as it would be useful for others.
