No wifi calling
โ07-05-2025
16:28 PM
- last edited on
โ11-05-2025
13:39 PM
by
JodieC
I have tried everything smarty have suggested concerning WiFi calling. I have a Samsung A55 5g handset and I live in a rural area so I NEED wifi calling, and I THOUGHT I had it. When making or receiving calls, 'sorry I can't hear you' is something I constantly hear as my signal drops in and out.
I need something that actually works, this is a deal breaker on staying or leaving Smarty.
- Labels:
Wi-Fi calling
โ13-05-2025 18:45 PM
Hello Tina, I've had the same problem but have solved it. Even if you have Wifi calling enabled on your phone, it may just default to using the cellular signal from your nearest mast, even if that signal is quite weak. When you are at home, try switching on the AIRPLANE mode, and make sure your phone's wifi is switched on. This disconnects your phone from the cellular signal, and will force your phone to use Wifi calling. If this works, you will get a notification, or a symbol may appear at the top of your screen showing a telephone and a Wifi signal. Or when you go into your phone app to make a call, a wifi symbol will appear on the connect call button near the bottom of your screen. This fix works for me, and I've got a Samsung A52. You just have to remember to switch the airplane mode off again when you are out and about, so you can make and receive calls using the cellular signal as normal.
โ13-05-2025 15:10 PM
@TinaCot_1748875 WiFi calling works if the phone has no mobile connection when you make the call. If the area you live in has a poor signal, this may be a problem.
Did you look at Coverage and Network Status checkers?
โ11-05-2025 13:39 PM
Thank you for reaching out to our SMARTY community forum!
Some devices may not be compatible with SMARTY WiFi-Calling, unfortunately, your device is not listed on our website although your phone does have WiFi-Calling.
Please see here:
Which devices are compatible with WiFi Calling? | SMARTY Help Centre
I hope this helps!
- Jodie
