No signal when leaving house
robertc_3189722
I use WiFi calling at home. When I leave home I noticed I have no signal. So I restart the phone and then have a signal. This never happened before with previous provider. Is there perhaps some settings I can change in the phone to help over come the issue? Using IOS
5 REPLIES 5
@robertc_3189722  Have you done a Coverage Check for your area to see what the signal is like there? Also a Network Status check for any local mast issues.
Is it like that everywhere you go?
robertc_3189722
Yes made coverage signal checks before moving over to Smarty two weeks ago. Issue is yesterday leave home fives into walk notice no signal. Today leave home all fine have a signal.
@robertc_3189722 Temporary hiccough?
robertc_3189722
Could be, I was more thinking error in SIM, as it happens now again, so it repeats itself. Time will tell. Hopefully temporary ๐Ÿ™‚
@robertc_3189722  If in doubt, you can always order a replacement sim. You may lose service until you activate the replacement though.
