19-02-2024 16:17 PM
Hi..I am not receiving any incoming voice calls on my iphone. No calls go to voicemail but voice calls can be made outgoing. Only calls over WiFi fully work. I've checked call forwarding but it's not an option that you can open (it doesn't load up.when selected). Attached is the error message I receive when I check the status
19-02-2024 16:42 PM
@NigelAug_194872 Have you checked this out with Support Team via web chat? If it were just your phone playing up, wouldn't you expect calls to go to voicemail?
19-02-2024 18:13 PM
Thanks @MSF . I'll try that
