no connection
โ16-05-2024 14:19 PM
phone says i am not registered - have had smarty plan for some months. Also in sim manager only data is active calls and text greyed out
โ16-05-2024 14:56 PM
Are you in the Midlands area where SMARTY Mobile have turned-off their 3G network, @peterha_1958309?
Without a 4G capable handset with VoLTE support, calls and texts won't work in this area.
โ16-05-2024 14:58 PM
This is the Smarty community forum, we are customers just like you, we donโt work for Smarty.
Try removing your SIM card and reinserting it in your phone. If this doesnโt solve the issue, contact Smarty via webchat, available from 08.00 - 20.00 each day.
โ16-05-2024 15:34 PM
@peterha_1958309 Do you mean that your plan is data only? Or Is the situation as @Chalkychap says?
โ18-05-2024 00:13 AM
Hi @peterha_1958309 ๐
If this is because the 3G network has been turned off in your area (which happened recently in the Midlands) then just search 'VoLTE' and you will see many, MANY posts with regards to this problem. It may be that your device isn't supported by SMARTY and if so you may have to change to a provider that does, unless you can afford to purchase a SMARTY supported phone to stay with them.
https://help.smarty.co.uk/en/articles/8985136-checking-if-your-device-is-4g-volte-compatible
