Motorola G85 5G 256GB Mobile Phone
christo_1961322
Hi all just wanted to ask here if anyone is using a Motorola G85 5G 256GB Mobile Phone on the smarty network having to upgrade due to the network changes and want to check before buying
christo_1961322
Well I went ahead and bought one and fortunately yes it does work with Smarty
Unitysounduk
Hi Motorola g85 5g is a 5g phone which should work on smarty
Hope this helps
