โ03-05-2023 14:49 PM
Hi all,
I have an Oppo A94 5g on Smarty and my wife has an iPhone 12 on O2.
Calls keep disconnecting in mid-call whenever she calls me. (She works at various locations in London, whilst I am home in Surrey). Any ideas for things to try to correct this would be gratefully received.
Thanks, all.
โ03-05-2023 16:31 PM
Hello @PieterSan_30971 . The problem is, does the fault lie with smarty or with O2? Have either of you had the same problem calling people on other networks recently?
โ03-05-2023 16:36 PM
Hi MSF,
thanks for your reply.
That's the crux of the matter...and I don't have an answer.
It only happens (every time) my wife calls me. It's fine when I call her, or she calls other people. I am still puzzled!
โ03-05-2023 16:50 PM
Hi @PieterSan_30971 - Very frustrating ๐ก
โ03-05-2023 15:42 PM
Hey PieterSan_30971,
We may be working on your local mast, you can check your network status here, https://bit.ly/3EzWp6u but if this is an ongoing issue our chat team can check your account, https://smarty.co.uk/contact and one of our advisors will be more than happy to help, available daily from 8am โ 8pm.
Hey Rebekah _150,
Thanks for your reply. I've checked coverage for my local area, (postcode SM2 7AZ) and there's no work on the local mast reported and coverage of 5g is good. Am still perplexed, as this has been going on for some time. It doesn't happen when she calls other people, or when I call her.
