โ10-03-2025 12:28 PM
Hi, I cannot make make calls or messages. I can receive them?!
I tried my phone settings but think this could be SMARTY related.
โ10-03-2025 13:28 PM - edited โ10-03-2025 13:28 PM
Hey @GeorgeP_3105809
We are sorry to hear this. Please can you confirm the following:
Thanks!
โ10-03-2025 14:43 PM
โ10-03-2025 15:33 PM
Hey, @GeorgeP_3105809
Can you try the following troubleshooting steps, and report back on the results:
1) Restarting your device and/or resetting your Network Settings (this does not affect your device storage, apps, pictures, etc.). This will refresh your connection to the serving site, prompting a stronger signal.
2) Toggling Airplane Mode/Mobile Data off and on. This essentially resets the IP connection, establishing a fresh new connection once linked to the network โ this will prompt your device and SIM to connect to a stronger signal.
3) You can remove any saved APN credentials, restart your handset and then re-add the required APN if your device doesnโt seem to automatically connect to a strong network signal โ please find guidance on the correct APN set-up via the following link: https://help.smarty.co.uk/en/articles/1155220-using-the-internet-after-you-ve-joined-smarty.
4) Please test your SIM card in a different device to determine if the issue continues.
Thank you.
โ10-03-2025 21:56 PM
OK, So tried points 1 to 3 and no difference.
Tried point 4 and used on another phone. The fault transferred to that phone, so its eithe the SIM or something SMARTY have changed?
โ11-03-2025 09:25 AM
if you are sending me a new SIM card, please send it to my temporary address;
George Poynton
17 Western Close
Ashby de la Zouch
Lecestershire
LE65 2FB
โ11-03-2025 13:26 PM
HELLO?
โ11-03-2025 16:34 PM
@GeorgeP_3105809 This is not a private space and so please protect yourself by never posting personal information.
You can order a replacement sim via your account dashboard and it will be sent to the address on the account details.
