GSM GPS SIM card
PhilJon_2239736
Does anyone know if they do a gps gsm SIM card to be used in a vehicle tracker?
Rebekah_150
Our SIM can be used in any, unlocked SIM enabled tablets, laptops or portable mobile WI-FI devices that is VoLTE capable and is uncapped for this use without data speed restrictions. The SIM card should not be used as a permanent long-term alternative to home broadband.
@PhilJon_2239736 There is the choice of either a standard call/text/data sim or else a data-only sim - the latter would probably work but only if it is not required to make any calls to the tracking company.
