Dongle wont connect
Options
โ28-06-2024 16:14 PM
I have a unlocked huawei dongle with an activated SIM. The dongle will not connect to the internet. Ive checked the APN and it appears correct (mob.asm.net). Anything else I can try?
1 REPLY 1
Options
โ29-06-2024 18:27 PM
@Lorrain_2806753 Are you using it inside a caravan or similar? Sometimes the signal is too weak due to metal structure.
I assume that you already checked coverage and network status for your postcode before buying the sim.
