Doesn't work new connection
JelenaT_2925120
Hello again! I did that you said everything  switch on plan and turned off the telephone  all the same nothing. What's happened? Thank you
1 REPLY 1
@JelenaT_2925120  You have started a new thread here. That means we don't know what you tried or the history of the problem.
Probably best for you to web chat with Smarty Support - https://smarty.co.uk/contact
