Changing owner number
Roderick_589766
I have had a data sim fo a while now which I use now and again. The number for this is my owner number. I have now set up a smarty sim for my phone. I would like the phone number to be my owner number as it makes it easier to verify when logging in and it is the number that I can be contacted on. can you help me with this?
1 REPLY 1
Strandloper
@Roderick_589766,
I can't think of a way you can do this without the help of a Smarty Agent through a webchat
