Changing number
AaronMi_2081680
Good evening,
I have changed from 3 to SMARTY and have submitted a request for a number change (to bring my old number with me). Can I use my SMARTY sim with the number I do not want on it for the time being until it changes?
5 REPLIES 5
ChrisGo_2486818
Hi Aaron,
If not too late, I recommend reading this post about porting issues before you port. Things do sometimes go wrong (we are all human after all), it just seems impossible to get any fixes from Smarty. FYI, this is still ongoing and not working for me currently
https://community.smarty.co.uk/t5/chats-hacks/still-no-service-after-joining-smarty/td-p/22427
Rebekah_150
Yes, once you have your PAC code from your previous provider you can make the switch, here is a guide to help. https://bit.ly/3Gijqeo
Tel557216
@ChrisAs_2490391  Not sure what this means.
Please note: never a good idea to post publicly any personal information.
Hello @AaronMi_2081680 Yo can use your smarty sim right away once it has been activated with a plan.
The only downside is that it will show a strange number when you call people you know.
The upside is that it usually takes very little time to port in your number to Smarty.
