โ03-07-2025 14:24 PM
I have had several people tell me they have called my number and they just get silence. No tone, No message.
I do not receive a call. Other times it is working fine.
Any ideas?
โ03-08-2025 22:03 PM
Ive also been fighting this problem on all of our iphones, we have 5 lines and each one has to be rebooted almost every other day before we can make or recieve calls. The single andriod dosent seem to have it happen as often.
This has been ongoing for a few months now, actually ive now started to look around for a new provider.
the phones that this happens on for us, - iphone 13, iphone 13mini, iphone 15pro max, and an old iphone 7 - pretty frustrating and im pleased now we are not the only ones suffering with this. This isnt a software issue with the phones as they are all running different versions, this is a smarty issue.
โ13-07-2025 20:40 PM
Iโve been having the same issues for the last 2 week, both my sons are also having the same issue.
callers just canโt get through, reboot or airplane mode on and off and you can make and receive calls for few minutes.
tested in different location and we have the same issue.
think we may need to go to another provider
online support have been useless
โ03-07-2025 15:27 PM
@BryanSi_2479947 Are they all on different networks - could the problem be at their end?
Do you have a good signal where you are?
โ03-07-2025 17:50 PM
On one of the instances we repeated the call when we met up. We were both within about 300m of a 4G/5G mast, direct line of sight. My phone didnt ring and the callers phone was silent. I have just finshed a long online chat with Smart support - they are looking into it.
โ03-07-2025 19:14 PM
@BryanSi_2479947 Good that you are having the issue looked at.
If you were both on the phone near each other, you would possibly not be using the same mast though - depends upon network.
โ12-07-2025 14:36 PM
Had someone call me on landline to say couldnโt get me on mobile.
Checked phone by calling it from wifeโs mobile. Dead response, no unobtainable message, nothing on wifeโs phone and my phone did not ring โ same as before.
I rebooted the phone and it worked perfectly.
The phone is new when I started with Smarty as the old phone was 3g/4g and didnโt work. So if the phone is new and assumed OK the SIM is from Jan 2024 so I ordered a replacement SIM โ arrived this morning so we will see how it goes.
โ16-07-2025 11:30 AM
Just had the issue again with new SIM. Spent an hour on a chat with Smarty. They say there maybe issue switching between Volte and 4G which there may be. BUT
Why does the person making the call not get some sort of unobtainable message. They get silence until the BT timeout tones - which must be a network issue.
