โ15-11-2023 22:10 PM
Anybody solve this problem.
My OTP code is not coming through. Checked all the usual things, blocked list,signal,sim removal etc.
The bank says the usual thing, all working our end must be your mobile provider.
Just to add all my other banking apps have sent OTP through and have arrived.
Any help?
Other people on other networks have had the problem.
โ16-11-2023 09:16 AM
@CHRISTIA_435669 Have you checked out what Seรฑor Google has to say on this? There seems to be a lot of info - some of it points to a network reset.
โ16-11-2023 10:03 AM
I have done everything I could find online. What's a network reset? All other banking apps OTPs work.
โ16-11-2023 10:08 AM
@CHRISTIA_435669 Depends upon Android or iPhone - It is in Settings. Again, Google will help here.
โ16-11-2023 10:48 AM
Yeah done that still no code.
โ16-11-2023 10:10 AM
@CHRISTIA_435669 Also very strange that you have no trouble with other banks/ May be worth a web chat with Smarty Support to see if this is a common issue with that bank.
