25-04-2024 06:29 PM
I cant call 0345 number even though I purchased add-on for premium numbers?
25-04-2024 06:49 PM - edited 25-04-2024 06:51 PM
0345 numbers are included in plans, so you didn’t need to buy an add on. See below
I have just dialled the “railcard” helpline, which is an 0345 number without any issue.
Are you sure you are dialling correctly ?
Which company are you trying to call, which number ? Maybe their lives are down ?
https://help.smarty.co.uk/en/articles/1088481-premium-freephone-and-service-numbers
26-04-2024 08:57 AM
@JJP2RidesAgain Just by way of further info on this, I tried an 0344 number the other day and was denied access. The number was definitely correct as I checked a couple of different sources - it was an insurance company. Managed to email in the end and so did not pursue it further.
26-04-2024 09:00 AM
That’s odd - I wonder if 0344 and 0345 numbers are treated differently.
26-04-2024 09:37 AM
@JJP2RidesAgain Just checked OFCOM and they should be treated as any other 01, 02 or 03 number. Confused now and may research it a bit more if I get fed up watching this layer of paint drying!!🤣
26-04-2024 09:43 AM
UPDATE:
Just tried the same 0344 number again and it connected !! I suspect that it must have been out of service the other day - annoying!
26-04-2024 09:58 AM
