Wi Fi Calling on Motorola G55 with SMARTY does it work ?
Vaughan_2065825
Is anybody using a Motorola G55 with SMARTY and does Wi-Fi calling work ? I am considering buying one of these devices but its a feature I need   Thanks
4 REPLIES 4
Vaughan_2065825
Yes it works I bought one but I have 2 Nokia phones, a 6.1 and a Nokia 8 and even though they are 4G/VOLTE devices that always worked fine on SMARTY they have both stopped recieving or sending voice, data and texts all good and they both work with Lebara and Gif Gaf (Vodafone and O2 I think), they should work but they definately dont, so they are no longer compatible with SMARTY for some reason
@Vaughan_2065825 Is the phone software definitely up to date?
Definately, the 6.1 is Android 10 and the N8 is Android9 all aps nupdated too) have come across a couple of posts on the Nokia forum the same, it seems that even though technically the devices meet the minimum spec (4G, VOLTE) they are not whitelisted at the  network end. Its ok I have switched network (Lebara/Vodafone) and donated the phone to my son and it works fine, no helpful suggestions from Smarty support, if they tried one they would find it doesnt work but its an older phone now and probably isnt a big enough concern to sort it out, they both work with GifGaf too (O2 I think)
@Vaughan_2065825 Don't forget that wifi calling only works when there is no mobile signal available.
