Using Smarty data in Europe
PETERSW_2239062
Using WhatsApp in Europe
1 REPLY 1
@PETERSW_2239062  You are doing that....or you want to do that?
Assuming the latter, yes you can if you set your device to mobile data roaming and make necessary settings changes. There is a 12Gb limit to roaming and also limited to 60 days.
Anyway, it's all in the help section of the website, so a quick read will explain all.
