Sim card no work
Miroslaw_400248
SMARTY Enquirer
SMARTY Enquirer
My Sim card doesn't work when I try make phone call it showing me can't connect to mobile network
1 REPLY 1
JJP2RidesAgain
Have you activated your SIM card and bought a plan, which gives you minutes, texts and data to use ?
Are you using the SIM card in an unlocked phone, which must be at least 3G capable ?
2G phones won’t work with Smarty
