Options
โ05-04-2023 14:15 PM
Options
โ05-04-2023 14:23 PM
Hello @Renzo___88 , sorry to hear that you are having problems.
Probably best to input your postcode on the Network Status checker first to see if there is any known issue: https://smarty.co.uk/network-status-checker
1 REPLY 1
Options
