Samsung A401
MarieS3289849
SMARTY Enquirer
SMARTY Enquirer
Can't make calls only place messages
Decembersangel
Hi @MarieS3289849
If you can send.receive text messages and use data but not able to make/receive calls then you need to check that your handset has VoLTE enabled.
To enable or disable VoLTE on a Samsung Galaxy A401, navigate to Settings > Connections > Mobile networks and toggle the switch next to "VoLTE calls"
Rebekah_150
Hi MarieS3289849,
If you do still need help, our customer care team are available daily from 8am โ€“ 8pm.  https://smarty.co.uk/contact
