Porting Issue
โ13-05-2025 16:12 PM
I successfully ported my existing number to Smarty today -13-05-25. Smarty informed me their via e-mail at 15.00pm today, and it said so on my on-line Dashboard.
My old supplier - 02 - said they were disconnecting me at 13.30 today.
However my wife tried a test call to me at 15.30, it did not ring, but went to my old suppliers Answerphone.
How do I get my Ported No. properly working on Smarty!??
โ14-05-2025 11:12 AM
If you havenโt already done so, you could try the below to potentially regain a connection. If you are still having issues after this our customer care team are on hand to offer account specific advice https://smarty.co.uk/contact available daily from 8am โ 8pm.
Restarting your device and/or resetting your Network Settings (this does not affect your device storage, apps, pictures, etc.). This will refresh your connection to the serving site, prompting a stronger signal.
- Toggling Airplane Mode/Mobile Data off and on. This essentially resets the IP connection, establishing a fresh new connection once linked to the network โ this will prompt your device and SIM to connect to a stronger signal.
- Please try your SIM in another device, to confirm that this is not a handset compatibility issue
- You can remove any saved APN credentials, restart your handset and then re-add the required APN if your device doesnโt seem to automatically connect to a strong network signal โ please find guidance on the correct APN set-up via the following link: here
- Resetting your network settings will remove all Bluetooth pairings and stored Wi-Fi networks.
- Open Settings and then tap General management.
- Reset, and then tap Reset network settings.
- Tap Reset settings. You will prompted to enter your PIN or password to continue if you have one set.
- Finally, tap Reset.
