Network issues, Call Issues, SMS Issues
AllaIhn_3228934
Please tell me how to fix it, I have a Smarty SIM card installed on my Android smartphone, all settings are installed, 4G+ internet works, but I can't call, send, receive calls and SMS. My tariff includes unlimited calls and SMS, and 100Gb. The support webchat doesn't work, I didn't find a solution in the FAQ.
@AllaIhn_3228934 Have you checked that your phone is compatible with Smarty VoLTE protocol? https://help.smarty.co.uk/en/articles/8985136-checking-if-your-device-is-4g-volte-compatible
My smartphone has VoLTE enabled.
The smartphone has VoLTE capability. It does not send or receive calls or SMS, only 4G Internet works. How can I contact online support?
