โ27-11-2024 18:00 PM
Hello, New Customer here, I have paid for my Smarty Sim Contract, I pressed the button 'Maybe Later' for phone. I now have my PAC Code from EE and I need to put it onto my account in order to Transfer to Smarty. I've been told to go to Dashboard/Settings but not having much luck finding the box to put in Phone Number & SPAC. I'm not able to Text as the Sim is used in a Wi-Fi Router, as I live on a Canal Boat. I hope this makes sense. Thanks in Advance.
โ27-11-2024 18:11 PM
@StevenP_3066945 If you navigate to your Account Dashboard on the website to this part: https://smarty.co.uk/dashboard/settings/phone-number then you should be able to enter the number you want to transfer over and the PAC code.
โ27-11-2024 18:41 PM
Hi, thanks your link took me straight to PAC box and I was able to put in my phone number & SPAC/PAC. Thanks for your time and effort.
โ27-11-2024 18:42 PM
ALL Sorted, thanks for your time and effort.
โ28-11-2024 08:22 AM
@StevenP_3066945 De nada!!
