11-22-2023 09:48 AM
Going to Barbados next year and want to know should I turn off data roaming as when I went earlier this year I used £15 add on in 10 minutes without using my phone, which then left my phone unable to receive calls from uk.
11-22-2023 12:11 PM
@JohnWil_1664617 I think you are correct. If you turn off mobile data, then you shouldn't be using up credit.
Looking at Price Guide: https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*1rzxt58*_ga*MTU4MjA5NjUwOS4xNzAwNDcwODMz.... It's still going to cost you £1 per minute to receive a call while there.
If you can, feeble wifi may prove best with calls via something like WhatsApp.
11-22-2023 12:12 PM
...that should read..... freebie wifi
