21-01-2025 17:00 PM
Hi all. If I travel from uk abroad or even to ROI do I need to change the roaming settings on my return put them back to three.co.uk?
21-01-2025 17:21 PM
@GaryGra_3137274 No, as it is a one-off change. I changed mine many moons ago after joining Smarty and traveling to EU and have never fiddled with the setting since then.
21-01-2025 17:25 PM
So if I do it now it won’t make a difference for just using data here in uk?
21-01-2025 17:40 PM
@GaryGra_3137274 That's correct. In fact, I just checked that my phone currently shows mob.asm.net as the Mobile Data APN and has done so consistently since I never change it before going abroad or when coming back.
21-01-2025 17:43 PM
Brill. Thanks
