08-24-2024 07:20 PM
Our MikroTik router is operating in a marginal signal area on 2G/3G.
What will happen when 3G is dropped?
Andrew
08-25-2024 09:07 AM
@HarlawH_2344123 I understood that 3G was being turned off to allow masts to have a greater 4G capability.
In theory, you should be able to get 4G signal when 3G is turned off if you have a compatible phone/device.
08-25-2024 01:52 PM
That's what I had hoped. But not clear how that will work unless they boost the 4G signal at same time?
08-25-2024 06:05 PM
@HarlawH_2344123 Yes - there is work on masts quite regularly and I imagine that a lot of that centres around boosting the 4G before the 3G disappears.
08-26-2024 11:56 AM
OK. I will go up to the site and check whether it is showing 4G or not.
Thanks for all the input.
08-26-2024 12:05 PM
@HarlawH_2344123 De nada !!
