Trouble Sending messages
DarrenN_1037318
Trying to send a paid text to a radio station. Just get Trouble Sending every time?
 I have an address on thinking it would sort the problem out.
1 REPLY 1
@DarrenN_1037318 Are you trying to send the text to a number with 5 or 6 digits? If so, Smarty does not currently support the Short code text system and so you will not be able to do it. Even if they did support it, there is a chance that you would need to add credit to your account to pay the charges - it would probably not be included in your normal plan.
