โ03-03-2024 11:29 AM
I've got an unlocked Redmi 8 Note Pro which I'm in no hurry to replace. I'm unable to activate VoLTE or WiFi Calling on Smarty, and I'm aware that I'll be unable to make calls once the 3G network is switched off.
Are there plans to widen the range of supported handsets before the switch-off? Smarty's guide implies that any phone which is VoLTE compatible should work.
โ20-08-2024 21:20 PM
Now on Lebara for less money, with VoWiFi and VoLTE working fine. Shame about Smarty's lack of support. Let's not even get into my email conversation with the support team - sure it was a bot.
โ19-05-2024 14:24 PM
Thanks. Looking at the Redmi 13 Note Pro, but it isn't listed as supported yet. Will probably just change network. Shame really.
โ13-04-2024 23:33 PM
I am in the same boat as I have Redmi Note 8 Pro too. I have been with smarty for 20 months. But now I have no option but to leave smarty and move to a network which supports Redmi note 8 pro. I don't think you are going to get any reply here as it is a community forum and I believe no one knows if smarty will ever add support for this handset. The minimum I have seen is Redmi 11.
โ19-05-2024 14:41 PM
People read too much into the suooorted handset lists. My Asus Zenfone 9 wasnโt on Smartyโs list, but worked fine, including on VOLTE.
โ14-04-2024 10:54 AM
@Raj_1939 The is absolutely correct.
