Mobile Data wont auto-cnnect
Jase_2129323
Since upgrading my phone to Android 14 using a Pixel 6a I have the below issue,
Has anyone else experienced this? I usually have signal where I am and have checked the network coverage which reports no issues in my area.
2 ACCEPTED SOLUTIONS
Jase_2129323
Fixed now, I'm unable to remove the post, if admin can that would be great?
Hi @George
Slightly ashamed to say it was something as simple as re enabling Mobile Data in my SIM settings. I hadn't realised the update to Android 14 had switched this off.
Jase_2129323
George
Hi @Jase_2129323 do you know what caused this/what fixed it? If you do then it would be great to  share 😊
Hi @George
