Doro and Honor mobiles on Smarty?
Samantha4130
I’d like to bring my parents onto my network. Are their phones compatible?
Doro 2404
Honor X6b
thanks. Sam.
@Samantha4130 You mean compatible with 4G VoLTE?
Those models are not on the list of incompatible phones (well, the Honor 6X is - is that the same?). You can check by following this article: https://help.smarty.co.uk/en/articles/8985136-checking-if-your-device-is-4g-volte-compatible
That’s the thing. I can’t find a definitive answer for the Honor one.
